1966 b body interchange?
Cornelius
11:18 AM
Los Angeles
Is there any list of what years/cars I can grab parts from for my 66 coronet?
I want to do a big block swap and found a 64 K frame, and was curious if it will fit. Also if any year 727 transmission will fit.
Is any b body part interchangeable for the most part?
Thanks.
Don't need to swap K frames unless you have a slant six.
Some 68-70 body and interior stuff works.
Heck lots of fasteners are the same all the way into the 90's!
You'll have to be more specific about direct interchange.
It's a 2 door, automatic, hard top, slant six car. I want to put a 440/727 in it. Do I need a kframe swap or just the motor mounts that will fit a big block into the slant six k frame?
64 K will sit the motor back abit. You just need a V-8 K-frame. I have them for 66/7B for 75.00 plus shipping
You'll want a '66 or newer 727, the '65 and older 727's were cable operated for the push buttons.
1966 B Bodies can provide stuff for the 69ish years, my GTX entire front clip is from a 66 Coronet, couple small changes needed to be made, but, overall exacto!
