1968 gtx
tileman61
3:15 AM
ashland ma.
Little help step on brakes no brake lights but interior lights come on when u open doors no dome light but I have map light .
Check the fuses with a test light, check both sides and should light up, if one side doesn't, there might be the problem. I had the same issue with my '69 Bee. Would step on the brake pedal and interior dome light would come on but no brake lights (on the same fuse). Checked the fuses, and found the bad one.
If the brake pedal switch checks out OK, it is possibly in the direction indicator switch on the steering wheel.
thank u was the fuse
