anyone swapped to front and rear discs with a brake booster
benno440
7:31 AM
australia
just looking for info on people who have put front and rear discs on and what brake booster they used
1969 Coronet R/T
I bought the front and rear disc kits from Cass/DrDiff to convert my power drum to manual disc. I'm waiting on rear axles to finish the brakes. So, I can't comment on how they perform, yet. However, the quality is first rate.
http://www.doctordiff.com/
My 66 had power drums. So when I converted to disc I used a too small master cyl. In hind sight I should have used the largest bore mc I could find. What I did was unplug the booster vac. Worked perfect as manual brakes.
i was actually wondering if i had the wrong setup and was seeing what opthers have used .
well the problem i am having is that my pedal is stiff and brakes need my whole body weight to pull up, i have a massive cam but this problem has oonly recently arisen as they brakes worked alot better a few weeks ago, only seemed to make a problem when i put 2" carb spacers on
Sounds like super low vacuum.
My setup is a hodge-podge, but it works:
1970 Charger
12" front rotors on '75 Dart knuckles/spindles. 1980 Volare 2.75 calipers
10.7" Dr Diff rear disc kit
Power booster/Master cylinder from a 75 Dart with a Comp Cams vacuum storage can hidden behind LH headlights in the inner wheelwell.
1970 Charger
Power booster/Master cylinder from a 75 Dart with a Comp Cams vacuum storage can hidden behind RH headlights in the inner wheelwell.
thanks Gregory, i have decided to just go with a hydroboost system,
