SOLD 1965 Belvedere I Street and Strip
cashes65
6:51 PM
Illinois
Belvedere I post street and strip
1969 .030 440
KB pistons
true 9.5:1
custom comp solid with edm oiled lifters
new double chain and gears
ported 906 heads 2.14 1.81 valves hardened seats erson adjustable iron rockers
griffin aluminum radiator
mezeire electric water pump
msd 6al and billet distributor
demon 750 with annular boosters dbl pumper
40 passes
727 reverse manual valve body
a and a transmission low gear set (2.74)
FTI converter 9 inch 4000 stall 10 passes
b&m plate style cooler with earls 06 braided lines from trans
cheetah shifter
sfi flexplate
linelock
8 3/4 rear
3.91 gear
strange spool 30 spline
moser axles 1/2 x 3 studs
superstock springs
wildwood disc brakes up front
drum rear
15x 4 torque thrust ds front
15 x 8 wheel vintiques steel rears
275 65 15 mickey Thompson drag radials
painted in march black base and clear
no reconstructive bondo in car
no rust holes in car
trim and chrome are driver quality
all lights work including backup
body is 8.5 of 10 in straightness and retains all of its original panels
interior seems to be from a satellite not original to car
car is a 9 code "police" column shift bench seat rubber floor mat variety
certified speedometer is still in place
car runs high 11.80s on 93 octane $17000 firm not a penny less
:blob1: nice very nice car shouldn't taken long to sell good luck and thanks for sharing:headbang:
