1970 Challenger Curb Weight
they start @ a base weight of 3006-lbs with a 225ci slant 6 with 3 speed & 3119-lbs w/TF, 383ci - 4bbl w/727tf & 3 speed 3384-lbs funny they say w/4 speed it's only 1-lb lighter 3383-lbs, 383ci 2bbl 3 speed 3329-lbs, 340ci 4bbl 727tf & 3 speed 3252-lbs, 340ci 4bbl 4 speed 1-lb less 3251-lbs, 318ci w/TF & 3 speed 3186-lbs, 318ci 4 speed 3285-lbs, that's what I see...
not sure if that actually helps any
You'll have to add any options that you have. If you A/C, radio, power options, optional larger wheels, fuel in the tank etc. then start adding weight. Basically they were a b-body with a short trunk.
No AC No Radio, I will have to assume with the fiberglass hood, and me in it, 3300 lbs.
Thank you all.
