stanhope55
I am a novice welder but have done some. I am having some issues with my floor pan spot welds.
Basically, I have a Hobby Lincoln 180 Welder that I have wired up for 220v.
My floor pan is 18g and my crossmember metal that it lays on shows about 10g maybe 11 on the caliper.
Regardless, I have my welder set up for the thicker metal 10g which is E - 8 setting from the chart on the door of the welder.
I have the metal clean and weld thru primer. I am trying to hit the center of the hole to start and move the puddle in a circle. When I am done there is always a burnback of the 18g and a section that does not fill with the puddle due to the burnback. Looks like a pie with a piece missing.
I cant figure out if I am too hot, not hot enough ? I am holding the puddle for a count of 1000/1 and then trying to rotate the puddle.
Sorry for the long question.
HELP ?
HELP ?
