Fuse box mounting?
eddieb
8:04 AM
Bad Axe
I just gutted all the Factory wiring out of my 69 roadrunner,now looking for ideas and pics on where to mount new fuse box. It is a Ron Francis Express any help would be great,I am sure I will be back here with lots more ?'s
THANKS EDDIE B
Installed mine (painless) tucked under dash left side, mounted almost same place as original because its easy to get to. sorry no pics right now. I also terminated the dash wiring with me sitting in the drivers seat so I can work on my gauges comfortably instead of the usual hassle with no room. good luck!
I had absolutely no room anywhere (67 Satellite) to mount the fuse box (EZ wire) under the dash. I have an a/c car and with the size of the heater/ac box and all the other stuff I decided on the glove box. Won't miss the storage area (cardboard) as I have
the console box for necessary items. I used the cardboard box as a template to cut and bend a thin piece of sheet metal. Still have some minor fabricating to do.
THANKS EDDIE B
THANKS EDDIE B
Have you decided yet where yours is going to go?
