Dash trim question?
Cliff426
2:00 PM
Long Island
I have a question about these holes under dash and above glove box…am I missing a certain dash interior trim item??? Its a 69 RR. Thanks
did your dash have a dash pad? they maybe the holes for the clips to hold the pad to the dash.
I'm not sure….this is how I got the car…I'll have to compare it to others this Spring at some shows or cruise nights...
I have a 69RR, I have the holes as we'll. I assumed that Mopar used the same dash components for other models. I would be interested if some one knows the answer to your question.
Those holes where for the optional trim that GTX ,Sport Satellite and probably high end Coronets had Road Runner did not use it but never say never i am sure if you wanted it on a RR you could have ordered it and possibly got it
So do you think all the RR's had those holes…or could during the resto a dash from a GTX or Sport Satellite have been used?
The blue car is a Coronet and the red is a Satellite. They show the trim that fills the holes in your dash. There are two stainless steel end pieces and one anodized aluminum piece that runs the length of the dash between them. There may be some body plugs for RR. Seems odd to leave open holes in the dash and not the door (reference the plug below the wing window). If you have the chromed plastic trim around the instrument cluster this trim will not fit. It was an either or situation.
Dash trim I need.jpgCoronet RT dash with AC.jpgCoronet RT dash with AC(2).jpg
Yes, it is a little weird that they would leave empty holes/ I'll have to look at some other RR when the weather breaks around here….maybe the RR is supposed to have that trim as well?? Thanks so much for the photos.
[/QUOTE] Beautiful interiors btw. I just started restoring my 69 Coronet and I aspire to attain that look.
Beautiful interiors btw. I just started restoring my 69 Coronet and I aspire to attain that look.[/QUOTE]
Alas, those cars are not mine. I currently have the metal dash pieces off for polishing. So, I found a couple that illustrate the point. Patience is a virtue. It'll be worth it in the end.
Pretty sure RR and didn't have that trim. All of mine didn't. Satellite, Sport and GTX had it.
Here is the trim set.
So do you think its possible my dash came out of a non-RR? Could Plymouth just have left the holes in plain site on RR's? Do you remember seeing the empty holes on your RR's? Thanks
