43tutor
I'm getting ready to have my 400 bored so I can build a 451. My question is how critical is it to use torque plates during the boring / honing process? I understand this is to make sure the cylinders are pre-loaded (to simulate the heads being installed) so the when the cylinders are honed they will be as round as possible. Does anyone have any data about engines that were honed with or without torque plates? How much distortion is there in the cylinder walls? Just how critical are the torque plates? I could certainly see this on a race engine but is it totally necessary for street motor? I'm leaning towards honing with torque plates but is that a unnecessary expense?
I have thought about measuring the bores on my block and then installing the heads and measuring the bores from the crank side to see just how much distortion really happens after installing the heads.
I've been searching locally for a machine shop to do the work. If anyone knows of a good machine shop in the Upstate South Carolina region let me know. I have numbers matching block and don't want it screwed up.
