PurpleBeeper
That is a great looking car & congratulations! That 8-1/4 rear end is super-duper weak and I would be suprised if it would take even one full throttle blast of a 440. An 8-3/4" rear end is definitely the most reasonably priced way to go. If you can get $200-$300 together you can find a non-posi 8-3/4" rear end that will bolt right in & last as long as you need it. After you get some more money together, switching to a posi-traction setup with gears of your choice can be done for another $300-$400 depending on what you want to do with the car, and with the "drop out pumpkin" (only Chrsyler 8-3/4" and Ford 9" rear ends as far as I know) the change is super simple..... like a 3hr job doing it yourself with no special tools and a couple gaskets.... so if you find one the right width cheap, jump on it. Welcome to For B-Bodies Only & GREAT CAR!
