8 3/4.......3rd members all the same between A, B, C.....?
Propwash
4:10 AM
Island of Misfit Toys
Hey Fella's.....Quick question.
Out shopping for rear ends (no...not hookers), and was wondering if all 8 3/4's centers were the same between A, B, C, E bodies?
I know there is 741, 742 and 489 cases, but what i'm referring to is; Is a 8 3/4 741 center in an A-Body identical to a 741 case in a B-Body?
Thanks for your time!
Thanks 68383. I was going to post over at FABO as well, but seems every thread over there turns into an all out drama & bickering fest, somehow or another.
Yep, no difference. People used to get 3.55 or 3.91 741's out of old Dodge vans and put them in whatever.
Now there is an odd duck 8.75" housing but I believe it physically will bolt in and work. It has a different casting number too and looks a little odd, but dimensionally I believe it's the same. This unit is very early C body I believe.
Fabo is definitely peyton place. lots of rude guys in my opinion. what is with them anyway?
I own A bodies, but they are really out there.
all will bolt in as for the yokes there is 7290 and 7260 size u joints and the yokes for 741 and 742 are coarse spline and 489 are fine spline
Which leads to the question what about swaps between open and sure-grip centers? Do you remove axles, remove the open center, install the sure-grip center, then reinstall the axles?
741, 742, or 489 are ALL GOOD!!!! The 489 has a cone sure grip, while the 741 or 42 has a clutch style sure grip. Get a 742 or 489 for the simple fact more gear ratio's are available. Other than that, burn some tires.
