64 drop spindles
lxmodguy
Gen3 Hemi Guru
7:20 PM
Texas
I have stock spindles on my car with wilwood disc brakes. I need to put 2 inch drop spindles on it to get it to align correctly. I would like to do it without changing the disc brakes. What have you guys used in the past?
The only place I know that has 2 inch dropped spindles is Fatman.
There ya go!!!
If the control arms used in AJE set up uses the stock mopar ball joints which it looks like from the pictures on their website then you should have to issue using our drop spindles.
James
I'm currently running the magnum force 2" drop spindles
