uwss
The upper control arm bushings I got for extra cam adjustment are .28" smaller than the original is there a way to compensate for this ?
really know one has any ideas on how to fix this? Standard bushings are bigger for some reason. I was told to use the ones for extra camber. However, they are .18" smaller each bushing. hole measure 1.88 and the nappa eccentric bushings measure 1.70. Big difference.
If you buy the standard bushings they are 1.88. Wish I had known these before I install them. I will have to make a harden shim now.
Know one really experienced the same issue ?
