- 7:22 PM
- Nov 20, 2013
- Ft Lauderdale fla.
After changing the water pump seal to one made to handle atf/hydrologic fluid and the hoses and bypass... running no heater box and lines but that should work with upgraded hoses also And a brass valve.... it won't boil over and transfers heat good.... the only down side with a blown head gasket you could run off the fluid if used in a diesel engine.... mineral oil will also work like it did in turn of the last century heavy equipment and trucks...
