rebuilding the frount suspension
Roger63
9:28 AM
Skiatook ok
Ok while I am waiting for my car to sell I have taken on the refurbishment of the frount suspension. After replacing all the bushings I attempted to reinstall the lower control arms.They wont go on the pins al the way any tricks? Please let me know thanks:happy6:
Yes thats right I left the pins mounted to the k frame because when I disassembled the lower control arms slid right off due to being so worn out. And the new ones won't go on.
The pin needs to be removed from the k-member (undo nut and knock out) and the remaining inner metal part of the bush needs to be removed from the pin( I usually hacksaw or carefully grind in a spiral). Then the pin needs to be pressed into the new bush..
Ok thanks for the info I had already removed the rest of the old bushing. But had not removed pin yet from the k member.
Yep, make sure the old sleeve from the bushing is not still on the pin, it can be hard to tell sometimes.
Thanks all got er done. Ia m a dumbass sometimes. But once I read the advice it al made since. Been a long week
Very good, short explanation.
Got it all back together again and on the ground. Off to alignment shop and to a cruise
to press out that busing i made this with a bolt, washer and piece of steel, pressed them out with a vise in like 10 sec
