Stock to mild 318 build
5:14 PM
Boaz,Alabama
I have got a 68 coronet 440 deluxe that I am in the process of building. It came factory with a 318 2bbl/ 8 3/4 rear end /Bench seat on the column. I'm in the process of stripping the motor apart as i'm typing this . It was running fine when i pulled it but i need a little more peppy action out of it. I'm 16 years old and my dad bought this car for me last summer and we drove until 2 weeks before i got my license and we decided to strip it down to repaint. (Typical rust in quarters,trunk, deck filler,and floor pans). My Dad has had muscle cars all his life and always been a Mopar fan . He owned 2 1970 challenger rallies that he sold int 1990 to put a down payment on our house with. But anyways the build is a plan that i came up with myself by searching here and there on similar builds to mine . Any advice would be greatly appreciated .
68 model 318 La
10:1 compression on pump gas
Crank turned .10/.10
0 decked
Machined / cleaned/ and new plugs and cam bearings
Factory rods
KB167 Flat tops with valve reliefs
.030 over bore
Milodon high volume oil pump
Milodon pickup
Milodon 6 quart deep sump oil pan
Comp xe284h cam kit ( cam and lifters) 284/296 duration
1998 magnum 5.9 heads
1.92/1.62 valves
heads are 59cc
.040 head gaskets
1.6 pro comp roller rockers
Comp double roller timing chain
Home porting heads
Summit Air gap dual plane La/Magnum intake manifold
Holley 770 street avenger
Custom Pushrods
New felpro gasket set
Hooker comp headers 1 7/8'' (3 inch collectors)
Any help and advice would be greatly appreciated. i already have the heads, intake , headers, carb, cam, and roller rockers by the way. Thanks
Close this thread and pay attention to the other identical thread.
After all that, you do realize that it will still be a 275 hp engine.
Uh yeah. I don't see anything that was changed from the original post but I didn't read every single word. Is there a difference between the one that was started and this one?
