Side marker reflectors on a 69 Roadrunner
Rustyiron
7:08 PM
Texas
Are side marker reflectors available? The ones on the car are tired and worn.
Ppg, classic industries, year one, just to name a few
The lenses and bezels are the easy part, good luck finding mounting brackets though.
I am not sure about the mounting brackets? I was thinking they have tabs on the back of the reflectors that snap in to the housings. I located a set of mopar originals that have the tabs. Maybe these are for a different year?
The housing/bezel has a bracket that is attached to it with 2 speed nuts. The bracket that is used with those speed nuts is what's hard to find. This bracket is what holds the bezel and lens assembly in place from inside the fender/quarter panel.
I will have to go look at it. I was thinking the bezel did not have to be removed to change reflectors.
No, the bezel does not need to be removed.
I'm afraid I may have been confusing the situation.
No problem I am just trying to understand how they are attached before trying to remove the old ones.
