jenkins71
Hey guys, me again. I will probably be dropping my 440 block off at the machine shop tomorrow.
My plans are to have the cylinders honed, the main cap alignment check and honed if needed, and the deck milled .025".
I am using a gasket that's .045" versus the steel shim that was in there of .020". I am milling the deck to keep compression up as it is cheaper than fitting new pistons, and more cc's removed than milling the heads.
I am also planning on capping it off with a set of 440source Stealth Heads.
So, the question is, will the intake fit with that much milled off? I feel since its just the difference between the stock gasket and the new composite gasket I should be fine. And pushrods, will that be okay?
Thanks for any quick response before I drop off the block tomorrow morning!!!!
