1964 savoy doors
old redneck
New Member
12:55 AM
north georgia
I need two complete doors for 1964 savoy /mine are hollowed out with aluminum riveted over with lexan wanting to put back on street and track.Also need back regulators and window tracks also
re the vent windows still in it? That's the front track. Add a piece of Lexanthats the stock shape and a strap. Then put the factory panel back on. Just fix the Lexan in the up position in the rear.
Doug That is real nice the way you did yours. My vents are still in but the top strip of the original on the inside door is gone maybe I can find some rusty doors to cut the top strip off and tig on mine. Thanks
sdn parts
Red
What do you need in parts? Were the inside of your doors cut where the regulators fastened? The reason I ask is I have 2 dr sdn (64-65) doors that are complete but only good for parts.They are complete,regulators,glass,vents, frames ,most have latches,linkage,and I have done research all parts can be used to convert 2 dr ht doors if you had too. The inner structure of the doors could be cut and used to repair doors that have been whacked.
Can take pictures if needed.
Jeff
Red
Jeff
Hey Jeff I could use some parts from those doors. Can you help me out? I tried to pm you but no option.....
I have both doors............complete with the windows and regulators.
I need some the inner opening handle mechanisms, left and right and handles. Which can be seen in the 1st & 2nd pics in post #2. Anyone have a spare pair of those?
I have the door openers, most likely the bolts for them too.
I parted out 2 Savoys and saved a lot of hardware.
I also have the front and rear window regulators.
64 savoy doors
$800-$1,000 pair IF you can find them… OR do it Doug’s way.
Jeff, My doors are perfect outside ,they just hollowed out the inside.Cut away everything but the vent window tract. I need your doors if you still have them.I can cut the inside out and tig it in and have all the hardware to. pm me if they are still available.
Thanks Old Redneck
