Malicious
I'm about to do a really basic refresh/assemble on the 440 I brought and I've got a few probably stupid questions that I'm hoping I can get some help with.
First up: the engine is a cast crank but didn't come with a torque converter. I have a torque converter that came with the car that I was going to run. I have just rear that the cast crank engines are balanced on the convert or as well? How do I go about matching up balanced unit?
Can I balance it? Do I need a special toothed plate(flex?)? How do I identify if I have one already?
Can I balance the torque converter I have to the crank? Or is that something the machinist would do?
Part two: I have a set if iron rockers and shafts separate that I wouldn't mind putting on instead if the pressed rockers. What am I going to need to swap them over?
Thanks for any help in advance!
