SOLD Brand new fuel tank for all 1971-72 b-bodies
74Satellite
6:28 PM
Syracuse, NY
Fuel tank For Sale
Shipping from Syracuse, NY
Price: $85 + actual shipping
Payment Methods Accepted: Paypal
Brand new never used Fuel tank that is correct for all 1971-72 plymouth and dodge b-bodies. Will also work for 1973 and 1974 but the vent lines are in the wrong location with require some modification
[Will post pictures when I get home]
here are some pics, the box it came in stated 71-72 Superbee on it
Will not work on 71-74,charger because they are rear center feed filler neck
I'm 99.9% sure that this is the Spectra Premium CR10A tank for 71-72 B Bodies. The hole for the filler neck is not pictured. The hole seen in the second pic is for the sending unit.
ok here are some information for shipping as requested by several people. I have it all boxed up, measured, and weighed.
Weight is just shy of 27 pounds
Measurements are as follows: Length: 36" Width: 28" and Height: 12"
I have looked up shipping through USPS and UPS ground with these measurements to the requested zip codes as follows (I will also be sending individual PMs to each of you in case you don't get around to reading the post)
ZIP CODE----------USPS----------UPS Ground
______________________________________________
75601----------$96.03-----------$77.52
14001----------$63.04----------$41.81
11727----------$67.99-----------$47.29
98516----------$132.29---------$100.11
12243----------$63.04----------$38.62
Obviously it appears that UPS Ground will be the cheaper option of the two. Ill be happy to look up any other zip codes now that I have it packaged.
SALE PENDING
