Mirror mirror on the wall
Dreadl0ck
3:04 PM
Sweden
Two questions in one post really
1) How do you tighten the mirror in the coupe? I tried to use a fitting bit and tighten it, but it just goes round and round inside the mirror. Mine is wobbling all over the place :)
2) Are there any passenger side mirrors you can buy (don't need adjustment from the inside) that looks like the drivers side on my 1969 roadrunner? It's a PITA to back her inte to the garage with only one working mirror. I put rubber foam om the garage door posts lol.
I have considered hanging mirrors in the garage so I know where the front end is also when backing in to eliminate all those blind spots. If there are 2 screws in your passenger side mirror it is screwed to door sheet metal only. The holes will have to be fixed to mount the mirror solid.
The passenger side mirror (check ebay) is very useful but it has to be aimed very precisely to help much. Consider cutting down a larger convex mirror (i.e. from a truck) to glue over top of the original mirror. It works!
