WTB Drum Puller
nm9stheham
12:22 PM
Waynesboro, VA
Feedback: +0 / =0 / -0
Looking for a US made 3 legged drum puller for pulling the brake drums off of tapered axle Mopars; needs to be the type with the bar that you hammer on out on the end of the threaded center shaft. Please PM. No foreign made ones please. TNX!
I got mine from Snap-On. It's been awhile. Maybe they don't make them anymore.Just a thought.
I got mine from Mac tools years ago. I can rent it to ya if needed ?
Drum and hub puller
i think this mite work i saw someone using one for a brake drum once
http://www.harborfreight.com/5-ton-three-jaw-hydraulic-gear-puller-95326.html
This would be the proper puller below ,as the hub and drum are one assembly.
This puller pulls on the hub and presses against the axle.
The wheel studs are swedging the drum and hub together as an assembly.
The puller suggested above would pull on the drum and press on the axle,distorting the drum.
attach=config]239334[/attach]
ATTACH=CONFIG]239336[/ATTACH]
ATTACH=CONFIG]239337[/ATTACH]
