Retiring and parts must go-many are new in box
truetriplex
6:25 PM
Ball Ground, GA
Feedback: 3 / 0 / 0
After 30+ years of Mopar restoration, it is time to retire. I am in the process of compiling a list of items that should be of use to some of you. Mostly B body, some E body, and many convertible pieces. I have HP motors, date coded carbs/distributors/manifolds/alternators, etc. Remember, if you don’t see it, you may want to ask. And you are free to throw me an offer too.
Many items are NEW still in packaging and are so listed. There may be some shelf wear. For reference purposes I have tried to list part numbers (mostly Year One, Mopar, OR OTHER). Items may NOT be from these suppliers but are always top quality that I used in high end restoration. Again, I do this for reference only. You can check the YO web site to see if this is the item you need. Price does not include shipping or handling.
LOCATED IN SOUTHERN CALIFORNIA
66-72 A/B body Sway bar end link set (NEW in package) $15
66-72 B body Upper control arm bumpers (NEW in bag) (reference to FD5204) $7.50 EACH
68-70 B Body lower control arms with sway bar- media blasted powder coated $150
73-74 A/B body disc brake calipers NEW in box $40
69 Plymouth B body under dash wiring harness (reference to HU271B) $350
56-71 Ballast resistor FR590A (NEW in box) from year one (reference to FR590A) $30
Points 209B244 (NEW in BOX)
Chrysler condenser 34206 (NEW in box) x4
Neutral safety switch – 3pin for 727 trans (x2) (NEW in BOX)
Flasher (NEW in box) year one 6503N
Starter relay – auto (NEW in box)
68-74 A/B/E Body Gas tank grommet x2 (reference to FD4182) $12
67- Plymouth Hood to radiator seal NEW (reference to FW935) $30
69 Air grabber 4 barrel lid only ORIGINAL (reference to WN3) $125
70-71 big block VC1 pvc value grommet breath (NEW in bag) x2 (reference to GR3447) $20
68-70 B body metal Hood pad retainers set (reference to J67) $32
Mopar master cylinder core
Dual alternator pulley $20
66-69 Negative battery cables 2ea 944 RT (NEW in bag) $30
67 – dual snorkel air cleaner lid ONLY big block (powder coated) $175
70-72 ABE Battery retainer (no bolts) (reference to MR628) $12
70-75 ABE Battery hold down with J bolts (reference to MR627) $25
66-67 B Body bumper kit body BBK1 (NEW in bag) (reference to BPK7) $22
68-70 B body Hood hinges $65
68-70 B body Gas tank lock ring NEW (reference to FD30095) $10
Filter fuel sock unit 3-3/8 1-5/16 (NEW) (reference to BG923 AND BG924) $13
69 B body Heater control valve AC $45 SOLD
66-70 AC vent hose BY PASS (reference to MT114) ($22)
68-70 B body USK02 under hood strap kit (reference to USK2) $14
68-70 B body A body Heater hose bracket fender mount big block (reference to AO336) $20
67-71 HEMI & 68-69 383/440 Upper radiator hose 2860186 NEW (reference to SR101) $50
Drain cowl flap (NEW IN BAG) RP 900-A $4
62-68 Radiator core support anti-freeze decal (NEW)
J- bolts battery (reference to HD1) $2
I have a 73 Dart with a 318. What are the chances you have the parts to convert over to HEI: ie distrib, coil, ecu, etc.
Also, what motors do you have? Any small blocks that have some extra get-up-and-go? Sorry to see you leaving the hobby after so long.
Only 200 miles North of you, so picking something up is a possibility.
Jason
I do have distributors but that is all. As for motors I have a couple of 383 HP's and a 340 block
I am looking for a non ac big block 440 alternator with a date code before April 68.
What do you want for neutral safety switches and starter relay?
Could you take a couple pics of the negative battery cable?
Do you have a BB bellhousing? I have a 69 Charger. I am really close so I could pick up. Thanks
I will check. Do you need the 10 1/2" or the 11", just to make sure.
I believe that all I have left is an early (Jan) of 69. It does not have a pulley on it.
Same here close to you. Can go over and buy in person....
I am interested - do you have any pictures?
How much shipped to Woodbridge Ontario Canada
L4L 7S9
Tony
Hello,
I am getting my '70 charger ready for rotisserie Does not really need it but I figured if I do it now I get everything done. Please contact me with anything for '70 charger or B body typical parts.
Thanks, John
I need a bb bell housing (large retainer) going 10-1/2 Cast iron dual point (BB)
Just found this old thread while surfing the web. I restoring a 1969 Coronet, non rally dash, and I'm in need of a dash wiring harness. Is yours still available/for sale? Thanks.
Chris
Hi!
1. 67 – dual snorkel air cleaner lid ONLY big block (powder coated) $175 Is this for a GTX?
2. 67- Plymouth Hood to radiator seal NEW (reference to FW935) $30 Is this available?
Interested in this item here: 68-70 B Body lower control arms with sway bar- media blasted powder coated, do you have any pics?
I see this is an old post but figure I'd try I'm interested in the calipers for the 72 b body's also do you have a stock oil pan for a 340 and a stock oil pump and pic up tube? Please p.m. if you have any of this left thanks also would need it shipped to 32907 Palm bay fl.
air cleaner DID come off a GTX at the time (2008). Not sure of other applications.. Still have hood to radiator seal.
Hi!
Sorry, but I can't help you on these.
Sold
Chris
from what I remember the air cleaner did come off (2008) a GTX. And yes, the hood to radiator seal is available.
Hi!
i am interested in the 67 parts except the dual intake,wish i had the intake. how much for all shipped to 07728. thanks
checking to see if you have an 11" bellhousing cover 69, 383 manual
Interested in your 69 dash harness HU271B. Is it still available?
Thanks,
Rod
Edit:phone numbers are not allowed to be listed in the classifieds. Thanks
