426 wedge 1964 ??? help needed to ID
gws4406
New Member
11:04 PM
Florida
New to forum but been Mopar collector with over 40Mopars since 1969..all sold.
I found a 1964 engine and trans that I believe is a miss match of parts.
Any help from veteran would help. I am not too computer savvy at 64. ThereforeI have photos and email but do not wish to beat the purpose of this forum. Ijust never replied or know anything about forums in all my years. My name is Geary ........................ Please do not post Telephone numbers or email addresses here as per site rules. Use Private Messages for contact info.
Located engine that is in ruff/ sad shape with 4 speed trans andbell housing. Believed to be426 wedge engine with 440 parts as follows; notesymbol
* indicates casting marksbefore and at end of numbers.
casting on side of block as a max wedge 2406730-1with R*L below casting
I am informed that the top of cylinder walls should ne notched. I pulled a headand the top of cylinders are not notched.
Casting on front pad by distributor as follows below
V 42? (dented/scratched/gouged but noclear stamp for "6" The 42 very clear)
4 22 HP
Heads believed to be 1966 dated 440ci due to casting date and # *283906 7 *
Intake manifold 2806178 alsostamped *11059 *
No marking found on bell housing
4 speed trans and shifter w/white shifter ball
removable plate on drivers side of trans C-95664
J
casting on driver side at bellhousing on trans *6810*
Any one with accurate knowledge is greatly appreciated.
Respectfully
Geary Senterfitt............
Hi and welcome aboard!
Thanks for joining the forum.
Seems like you found a nice GEM?
PS: Gary, per forum rules and your safety, please edit your post.
The forum does not allow telephone numbers and address.
Welcome, Geary. That's a 1964 426 street wedge block. The V is for '64 and the 42 means 426 (the 6 wasn't stamped on them, just the 42). The casting numbers for the street wedge and max wedge blocks are the same. In fact, the only real difference between the blocks is the presence of valve reliefs (notches). The max wedge blocks had different stampings on the engine pads, too.
Hi Geary, welcome! You ought to head on over to the 'welcome forum' and let everyone know you're here. :)
Are you sure of the numbers on the cylinder heads? They should be 7 numbers long, if you have 2843906 those were used from 68-70. The intake number is a 67-69 piece. You can look up some of those casting numbers http://www.mymopar.com/intakecastnumb.htm and http://www.mymopar.com/headcastnumb.htm
Gearry, My fellow wisconsinite is correct. You have a 64 street wedge. FYI. street wedges have no factory notches. The stamping would say 42.. a 383 would have 38. A max wedge would have 426 HP.. A street wedge has 3/8 oil pick up. Max Wedge has 1/2 oil pickup and I believe the max wedge blocks actually had a higher nickel content. Nice find!!!
My Street Wedge Distributor Boss Number Has The V42 And An A HP? 65 Plymouth Terry's Street Wedge 5.jpg
Yes, the street wedges have HP stamped on them, too.
Max wedges stamped MP and font style is different from memory but I am old.
That's what I thought, too. MP stands for Maximum Performance, if I'm not mistaken.
The only Max wedge engines that had HP was the 413 Max wedge with block casting #1852029
