69 Charger sump removal
blown69
New Member
1:08 PM
Christchurch
Can anybody tell me if it is possible to remove the sump from a 440ci 69 Charger without removing the motor. mine has split and needs to be replaced or welded up
Sump?
Do you mean "Oil Pan" ?
The oil pan will come right off if you drop the steering link, if that's what you are referring to.
yes I do mean the oil pan, over here we call them sumps. So you think its possible? what about the oil pick up, does it get in the way? cheers Paul
I know it is possible because I did it several times when trying to stop a rear main seal leak years ago. You might have to put a 1.25" socket on the crank pulley bolt to spin the crank a bit.
Yes it will but it's a bit of a fight. The oil pickup might limit some mobility and center link removal is a must.
