rikubot
My dash wiring was completely make-shift and my gauges were mounted on a piece of wood. The previous owner had all aftermarket gauges, and all the engine wiring was also his own creation. He had spliced the headlight harness and wiper harness into his wiring, and riveted a plate over the hole where the bulkhead connector was located. I recently purchased a dash and engine harness from Year One. I cut out all the wiring I could tell was his and on the dash side was left with mostly plug-and-play connectors, less the body lights and one or two other small things. Under the hood I began splicing the wiring back into the correct location on some salvage yard bulkhead connectors I cleaned up. I have everything hooked up into the bulkhead on the engine bay side EXCEPT the four wiper wires. On the interior side, I don't have the door switches, radio, heater, brake pedal, cigarette stuff, light by ignition, speedo and clock (no big deal), or console lights hooked up. I'll post a bunch of pics in that thread to show you what I've got going on under my hood.
What I have working:
- Car starts
- Headlights work (brights too)
- Reverse lights work (had to make Neutral safety plug out of salvage parts)
- Neutral safety seems to work
- Tail lights work
- Turn signals
- Left turn indicator
- Alternator Gauge
What I don't have working:
- the three gauges on circuit (assuming voltage limiter, going to do the solid state mod when parts come in)
- gauge back lights
- dimmer switch
- flasher switch
- right turn indicator
- dome light
- door switches (not hooked up anyway)
- washer fluid button
- brake lights
- brake indicator light (assuming it lights when E-brake is engaged?)
- wiper switch (no big deal as it isn't hooked up
I'm sure I left a few things out. My main concern is with the gauge stuff not working. It's mostly plug-in stuff so I figured it was a no brainer. Does it have to be bolted to the dash to work? I usually don't bother as I have to have it out all the time anyway since I'm trying to get it all dialed in. I'm pretty familiar with the diagrams but I have no experience with electrical and It takes me a while to figure routing out. But, so far, so good with the harnesses I've made (other than the gauge issues haha).
Any tips for grounds would help a lot too. I just realized that my column doesn't have a ground on it and apparently its supposed to? Ground locations would be awesome too!
Thanks for your time, it is very much appreciated.
-Mike
- Car starts
- Tail lights work
- Turn signals
- Alternator Gauge
- gauge back lights
- dimmer switch
- flasher switch
- dome light
- brake lights
-Mike
