MKCoconuts
Okay, to start, names Sean and I'm not a Mopar guy, I'm more of a GM guy, but my father is all Mopar all day. He owns a '66 Plymouth Satellite that was originally optioned with a 273. When we got the car, we went through the process of restoring the car. We stuck a 318 poly in it which ran brilliant. We then swapped that out for 318 LA, which also ran flawless. But he wanted a big block and we came across a deal on a 383 with the transmission that he couldn't pass up.
The deal ended up coming with the engine, trans, full rebuild kit, purple camshaft (I'll get specs when I get back home), electronic ignition, and other little things. We purchased a Edelbrock Performer series intake, part #2186, LT headers, a Cloyes Double Roller timing chain. We reused our Edelbrock carburetor 1405 from the 318 which we later found out was a 600 CFM. The car has a 2500-3000 stall converter and we believe 2.93 rear gears.
The trouble we are having is the car is a complete dog off the line, literally, my mothers minivan has more acceleration. Once it gets up in the rpms, it seems to pick itself up and go. I've tried coming with ideas on the issue but haven't found much info.
We are thinking of 3 possible causes:
1) Carb is too small
2) He got the valve timing off when he installed the DR.
3) Rear gears are holding the car back (I'm thinking this is mostly likely it, but he doesn't feel it'd bog the car that much)
Any help/suggestions would be much appreciated. If any one needs/wants more info on anything, I'll try getting it as I've been helping with the car. I'd love to get this figured out for him because it's gotten to the point where I think he's really serious about selling the car, regardless of how much he loves it.
