Quick engine removal question
66plysat
12:39 AM
Rancho Cucamonga, Ca.
I'm ready to pull my engine and need to disconnect the motor mounts. Are the mounts separated by removing the bolt so one half is on the k-frame and one half is on the engine. Or is the mount completely unbolted from the k-frame prior to the engine removal. Any advice will be appreciated prior to me pulling the engine.
I take the nut off at the K-frame. Use what ever is easiest to get at.
There's no right and wrong what ever is easiest for you wether it's split in half or just fully remove it from the k frame or eng what ever is easiest good luck
