SOLD Cross Ram Setup with Valve Covers
Hanover Mopar
10:42 AM
Northeast
I have gone through the Craig’s List and Ebay bullshit and I am done with it.
I do not want to ship so it is a local pickup in Eastern Massachusetts.
Please PM if you have any offers and can pick it up.
Asking $1,500
Jack
Mopar Cross Ram setup with 426 valve covers
This setup came off of my 1963 Dodge 330 / 440 Max Wedge tribute car.
This is a period correct setup (not original). This setup ran fine but the previous owner updated to a single 4 barrel. I am told the valve covers are original as they are only 4 bolt pattern but I cannot verify that. Includes linkage and intake bolts (one missing) but no valve cover breathers
Carburetors are Edelbrock 600 CFM. Correct Air Cleaners
Is this an aftermarket intake manifold and if so is it the one that fits 440 heads or the one just for max wedge heads? Thanks!
A stock M-1 was put on it by previous owner so I would assume it fits 440 heads.
A measurement of the ports would help, as well as any numbers cast into the manifold. The 4 digit number on the front left base of the carburetors will help with sizing them.
Ports measure 1-5/16 x 2 1/2. No markings on manifold that can see, assumed painted over. Carbs 600cfm Eddies built by Weber.
Could you post picture of intake with carbs off?
It appears that this manifold is for the max wedge heads. The port sizes are quite a bit larger than standard big block head ports.
