Headers For 1970 Super bee
1970superbee
11:17 AM
California
I'm am getting ready to install a 440 with a 727 and wanted to buy some headers. I have heard that some headers for b bodies have problems with clearance issues.I was looking for some feed back.
Thank you
1970 Super bee
TTI....buy once, cry once!
Buy TTI from a FBBO Vendor if you do buy. Not direct.
Check out OBX Racing stainless steel. They're available on Ebay and on special right now.
I have to agree TTI are awesome, BUT costly. I am always use manifolds, headers were a pain in the d!ck everytime I messed with them, UNLESS I was doing a build where I was going to be using every last ounce of power, manifolds are nice. HP big block manifolds can be found and restored or bought repopped, I dont even use headers on the small fi chevies I build, I use the old vette rams horns (repopped now, they are nice quality), you never have to tighten the up, they dont rot away, leak, get super duper hot and melt everything in reach of them, have ugly wrap on them, etc etc etc..
If its a race car that is different, big tue headers are a must, for a car you are going to be driving on weekends, daily, or to shows, etc, ci manis...
Yes, but the weight reduction alone is welcome. If you get the ceramics, the underhood temps are also reduced. Mine is 100 degrees cooler under the hood than anyone else with the coated ones. Weight and lower temps. Don't care as much about a performance advantage.
valid points, but again, are you that worried about weight with a driver, m cars have ci 6 pack manifolds, lol, you ever pick one of them up off the ground lol, or a shelf over your head...
I agree, as I said in previous post, racing, or after every ounce, headers are the guys, but for 90% of the rest of us, ci will suit us better...
If I am racing, I wont be doing it in a 25foot long chrysler, lol I would do a tube framed small/medium pickup truck. A friend of mine has a dakota body, aluminum bed (just the sides, no actual bed in there, its paper thin), 2 seats in it, around 900hp, link , tubbed, power glide 2 spd, etc etc etc , but it is streetable, has 2 seats in it, lights, a vin number, etc etc etc.. he drives it to work sometimes, lol (its powered by a big blown chevy though..)... He has the coolest rear end, I belive its a ford 9", he can swap gear sets and go from 4.10 or 11 to 5 something, not sure the specifics, but he swaps that gear seat and the tires in like an hour... he can drive the truck to the track, with the jack, wheels, gears, tools, etc in the bed, change them at the track, and race all day, swap it all back and drive home... The truck is capable of running much faster than he runs, but he dials it for aspecific time and runs that way, he said its just as fun and doesnt break anything (as often), so I guess his motto would be "you want to run 10.0's, build a 9.40 car and run 10.0s.......
I put the TTIs on my 70 Superbee with the Hemi
Easy!
Beautiful!
I did have to take my time on the passenger side....tight fit!
I did what Dennis H suggested: Ceramic, Polished
Got them for the 63 Polara also.
From my experience on my '70 Road Runner..... the Hooker 2" primaries go on easily (4 slip tubes), but they hang about 3"-4" lower than the oil pan & I smacked a couple pairs on curbs, etc. Hedmann 2" primaries don't go on quite as easily (1 slip tube per side), but they don't hang down below the oil pan. It was many years ago, but I think the Hedmanns needed one small dent on the driver's side to clear something. Both the Hooker & the Hedmann "big tube" headers have spark plug clearance issues. I've not got 1-3/4" primary headers (brand?...maybe smaller Hedmann's?) that have no slip tubes that were harder to install, but have no ground/plug clearance issues.
Installed Doug's 452's in my 440 Coronet. Bought them raw and had them ceramic coated - still less than TTI's. Installed my engine from the bottom (dropped the body down) with the headers already installed. Still a tight fit. Installing headers - sucks. Changing spark plugs - sucks. Replacing blown header gasket - really sucks. Replacing starter motor - really, really, sucks. The rest of the time - love 'em!
I installed a set of used shumacher Tri Ys on my 67 Coronet 383 with 727 column shift & power steering. I know they do not build the HP of the full tube larger dia. headers, but they are better than stock manifolds , sure sound nice through flowmasters and installed with no problems.
You can use a full size starter or a mini, starter can be changed without taking the header loose.
Only thing I had to remove besides exhaust & plugs to install them was the shifter rod bellcrank and rods , those went right back on with no mods. did not have to jack up the engine. both sides installed from the bottom up.
If I ever have to get a new set or put a set on another B body I would go with the Tri Ys again.
My feedback on this subject is to just go with the TTI and be done with it. Yes they will cost more, but they fit perfectly. The quality is second to none. You won't have any plug wires frying onto the plugs and the collectors end evenly at the cross member area. No regrets going with TTIs over here and the best fitting header I've ever installed.
And if you look around, you might find a set that someone bought and then sold the project etc. I got a brand new unused set for nearly half price because the seller decided to go in a different direction with his project and decided to use a set more geared towards all out racing. Gotta say, they are not just headers but they are built to look good and last. The head flanges are thick and so are the collector flanges.
Easy!
Beautiful!
I love your car..
I have my fabricator build my headers for each individual car. They're all different, somehow.
