Torque spec help
rebeldart
1:13 AM
saint augustine FL
In doing searches , I'm getting various info. Could anyone tell me the torque specs for the 4 K frame bolts on my 73 RR with rubber bushings ? Rebuilding the entire front end , have found "most" of the specs. Thanks.
If you have the "Isolated crossmember" (rubber isolators between crossmember and frame), then they get torqued to 75-80 ft/lb.
Yeah, my service manual is the same, but the diagram of the k-frame says 50ft/lbs, which I don't believe.
