 - 5:56 AM
 - Dec 4, 2009
 - Pasadena, Texas
Anyone have a good way to remove carbon from piston tops?
			some would trickle water down the carb with the engine running. I never tried it though.Are they still in the engine?
NopeAre they still in the engine?
I usually use either carb cleaner or decarb. If they're out, you can out them in a pan and let them soak for a day or so in a decarbon solution. Then just wipe the top of the piston off with a rag. Then scrub with a little soap and water.
Seafoam
