Max Wedge Exhaust system
426SFC
7:20 AM
Michigan
I am looking for opinions on what is a good reproduction Max Wedge system ,From the H pipes back as far as the fit and Durability stand point .Thanks for all your advise .
here you go tti 3 " SAM_1156.jpg tti sells 749 buy mne used 625 plus the ride
I was looking for advise on the Best fit and other Details like option on Material they are made .My first set years ago on one of my cars fit Horrible I don't want to go thru that again .Thanks for your reply .
tti is your best option...nuff said.
Thanks Everybody for all your input on this ,it helps much appreciated .
Accurate is the best. I believe they have all the original factory specs.
Accurate full system $1617.00 (Press bent pipes)
tti full system $1156.00 (Mandrel bent pipes)
Difference $ -461.00
For the price difference alone, I say tti is the better buy.
My originals have a pressed section on each for clearance of the torsion bars.
Do either of these manufactures have these also?
AFAIK, they don't mate.
Accurate are that - more accurate to factory spec including the reduced dia bends. TTI are less "authentic" but mandrel bent for better flow. Your choice.
This is a real Max Wedge Savoy it is Going on so I am looking for a Exhaust as accurate as possible to original .I have enough money invested in this car that the price difference dosn't matter as much to me ,Thanks everybody for your advise .
If this is going on a "Points Restoration" car and money is no object...then go with Accurate.
Yes That is what I was thinking ,Thanks everybody for your help .
Might want to check out the tail pipe size between to two systems
