The hits just keep on coming and I am about at my whits end. Got my vibration issue fixed so I go for a joy ride. Some spirited driving and a 5700 rpm shift later and there was a cloud of smoke following me.
Got home and took a peek. Oil had been dumping on the pass side header. Looked at the oil pressure switch, some oil around it so I tightened it and sealed it. There was plenty of oil on and around the filter so I pulled the filter inspected the adaptor which was tight. Put a new filter on, checked oil and went back out. Same thing.
Seems anything above 3k and it is squirting oil from an unknown location. There was oil covering the 727 bellhousing, the back half of the oil pan, center link, right side header, right side tortion bar.
I'm too mad to go out there right now. Where do I need to start? I have only the factory oil pressure gauge but could rig a pressure gauge to see where it is at.
New engine probably less than 5k on the rebuild (specs below). Has open breater on driver side cover, breather on pass side has a tube that runs down behind engine.
Could the rear main seal leak at high rpms and be fine just cruising around?
