440 slow to pick up oil pressure
John Milner
11:39 PM
Oklahoma
My 440 seems to be a little slow picking up oil pressure if the car has sit for several weeks. The engine is fresh with maybe 1,000 miles. It has a 402 pan/pickup and everything was normal there when I built the engine. I run 10w30 oil in in the engine and it currently has an STP oil filter. If the car sits for a few weeks and I go to start it up, the gauge will read 0 for about 10 seconds and I can hear the valvetrain clicking until it finally picks up oil. Once it picks up oil, it idles around 30 pounds of oil pressure hot and runs down the road around 60 pounds. If I start the car again the same day, it picks up oil instantly. I don't seem to have this issue on my other 440 I run in another car. I am tempted to swap the oil pump out for a different one. Does anyone have any recommendations or ideas on what might be the cause of this issue? Thanks
Use Wix. Never Fram! STP filter could be made by anyone, including Fram.
It sounds like the filter is draining back, making for a dry start.
Just for comparison, the V-6 Pentastar in my Grand Cherokee has a horizontal oil filter at the top of the engine, that drains back after engine shutdown. At startup, the engine sounds like a bag of metal balls being shaken. I ask the service guys at the dealership, and they say this is normal. If my 440's started up like this, I would be worried.
Yes, sounds like the oil filter is allowing drain back, probably a leaking internal valve.
filter drainback. Been battling this all year. So far the only cure i've found is the motorcraft fl1. Tried numerous brands, fram, wix, purolater, k&n, all had serious drainback.
After my cars sit a spell, I usually crank engine over a few times before ever setting the carb choke or touching the throttle. Watch your oil pressure guage until you get pressure. Then hit your throttle and set the choke.
So now you don’t know the root cause.
Fixed?
Is it a electric or mechanical gauge? Electric gauges tends to take a little longer to react.
The gauge I am using is a mechanical one. The oil pressure did change some. It now has a hot idle of about 35 and cruises down the highway at about 55. The best change was that I can now see the gauge pick up oil pressure when I am cranking the engine over when I first start it.
Getting off track just for a moment...
My brother uses the "Baxter Performance" adapter on his Chrysler V-6. No more drain back.
Spin-On Oil Filter Adapter
