filler neck to trunk seal?
hemiron
2:11 AM
sun Prairie wi
I've got a new filler neck to trunk seal and there's 2 ways it can go in.
I don't want to install it the wrong way just to have to drop the tank back down without scratching it all up! Anybody got a good pic of one for 69 charger? Got the seal from yearone. One side is flat the other side has a lip all around it. Thanks Ron
Slide the seal on the bottom of the tube. Loosen the tank up so it hangs a bit and slide in the tube. You most likely will have to lube up the tank O-ring to get the tube in.
trunk seal
Upside-down? Or the other way?
Other side
Just curious, does the location of the hole help you figure out which way it should fit?
As an add on to upper post, I removed the filler cap (shove a rag down the tube so the little screws don't fall down the tube) and slide the neck up, insert trunk/filler neck gasket then slid the neck back down into the tank.
