Ball and Trunion Refresh...A Tutorial
threewood
8:30 PM
SE NM
I like the B&T. Service isn't that bad and parts are still available. Much more cost effective than getting your shaft cut, and pieces added to allow the yoke to slip. As long as the boot is good, service intervals are few and far between. Plus, these held up well behind max wedge cars so it is plenty good enough for a 318.
Here it is from a driveshaft I got with a BB 727 pushbutton transmission. Boot is shot but there is no noticeable play so I am going to refresh it for a spare. Got the boot and straps on ebay for $25.00.
Take the straps loose and then with a small screwdriver pry up the dust cover clips and the dust cover pops right off. Wear gloves because it is going to be nasty.
Now, be careful. Hold the driveshaft with the u joint end on the ground and pull down the housing. Slide one side ball off (there is a thrust washer behind the needle bearings. Make sure this comes off with the ball or needle bearings will go everywhere). Same step for other side.
Now, if you are feeling frisky you can press out the pin. I wasn't so I left it in place and cleaned around it using mineral spirits and some brake cleaner. The housing won't come off with the pin still in place.
After airing it off and letting it dry, you can now install the new boot. Lather up the inside and out with vasoline and slip it over the pin and press, pull, shove, press, pull, etc. Once the small end pops through the other side, you can grab it (caution: if you use something sharp you risk tearing or ripping the new boot. Be gentle) I grabbed this one with small needlenose just enough to get a good finger grip on it. Then, with the u joint end on the ground, pull up on the housing as you pull down on the boot. A rag helps get a grip on the boot.
20160402_150416.jpg20160402_150519.jpg20160402_150651.jpg20160402_150936.jpg20160402_151146.jpg20160402_151225.jpg20160402_151230.jpg20160402_151417.jpg20160402_151915.jpg
Now clean, grease and reassemble the balls. There are 31 needle bearings per ball. Count them and make sure you have them all. Tweezers come in handy as this is tedious work.
Now carefully slide one side on then the other. Use plenty of grease. It is best to leave the small end of the boot loose to get better clearance on the pin. Before you tighten the last clamp, insert a piece of "polished jute" as stated in the manual. No clue on this so I used a piece of regular jute or even carpet fibers. Point is to allow air to pass into the boot so pressure doesn't pop the boot.
Grease up, re attach the dust cover and you are done. Gasket on mine was in good shape so I re used it with a bit of aircraft gasket maker.
20160402_142728.jpg 20160402_142814.jpg 20160402_142911.jpg 20160402_143025.jpg 20160402_143051.jpg 20160402_143233.jpg 20160402_154613.jpg 20160402_143916.jpg 20160402_145125.jpg 20160402_155118.jpg 20160402_150416.jpg 20160402_150519.jpg 20160402_150651.jpg 20160402_150936.jpg 20160402_151146.jpg 20160402_151225.jpg 20160402_151230.jpg 20160402_151417.jpg 20160402_151915.jpg 20160402_161425.jpg 20160402_162801.jpg 20160402_153642.jpg 20160402_153805.jpg 20160402_154541.jpg 20160402_163557.jpg 20160402_164159.jpg
Thanks for taking the time to document it - nice work!
And that is why I had mine replaced, never found inexpensive boots.
Big block complete shaft needing a boot make me an offer.
Great write up Mark. Before I forget the kickdown linkage rod is sitting in my garage waiting to get sent.
No rush :)
Sure, but the price of a boot maybe every 50,000 miles isn't bad. The boot kit I ordered above isn't an exact copy either. The original has an internal molded in sleeve on the large end. This one doesn't. But for $25 I ain't going to complain :)
Good tutorial Threewood. I rebuilt mine a few years ago and it's held up fine behind my 440/727. The hardest part is probably wrestling the new boot through the body with greased up hands. Also be really careful with those little needle bearings, they can be a bitch to find if you drop any (guess how I know). Like you said, the B&Ts held up behind Maxies and if you take care of them they will last practically forever.
I think this forum is where they originally coined the phrase......"You learn something new everyday." Thanks Threewood! :icon_salut:
nice work....great pictures....:icon_sunny:
Sonny is very visual & it helps
This is very helpful...thanks for posting this!
Are BB shafts different than SB's?
I'm going to say shafts of the same year and body are going to be the same, 6cyl and 8cyl. My 62 manual states sp-1 and sp-2 shafts are 53.64" for automatic.
I measured my 1962 Belvedere shaft (1962 SB) and the one I rebuilt above (1964 B body automatic) and the 1964 shaft is approx. 3" longer. 1962 and 1963 should be the same wheelbase.
