318 Engine Performance Upgrade
Aesellitto
1:19 AM
Evans, GA
I need some advice on my 72 Charger SE with a 318 LA engine. Here is what the car has at the moment. Stock block and the low flow stock heads. It has an Edelbrock performer intake and a Street Demon 625 4 barrel with dual exhaust from stock manifolds. A 727 transmission and 8 ¼ rear end with 2.71 gears (or close, no tag, but counted close to that ratio).
I have resigned myself to updating the rear end to 3.55 gears so it has all the help it can get for the low end but still be manageable for moderate to light highway speeds (the car is mostly a local driver). I am not looking for a super high HP rating (hoping for 300 – 350). The end result, at the very least, I would like to outrun a soccer moms lead foot if neededJ.
I do know that the car is due for a timing chain so that will be done. With that said, is there a significant advantage to upgrading to a mild CAM when I do the chain? With the low flowing stock heads is there that much of an improvement in performance/HP? If the cam is replaced with a mild performance cam is it necessary to change the push rods?
The other option I read about is looking for a set of mid 80s early 90s heads (not the Magnum heads). From all my research, they are a direct bolt on and perform better than even the J heads due to the combustion chamber design. Again, do I need to worry about push rod length if I swap heads?
I am not on a super tight budget ($1000 - $1500). There are tons of threads out there on this and they are all over the board. I was hoping for an answer that deals with my specific variables and budget. The big thing I am not ready for right now are headers. I don’t want to monkey with the shift linkage or deal with the intense heat under the hood right now. And the budget will get blown doing the exhaust the right way with ceramic coated heads into new exhaust that will need to be replaced.
I also am not interested in swapping out the 318 with a 360. For the price, I am going to get someone else engine that needs as much work as mine and the cost is going to rise quickly. The car is also numbers matching (even though it is a 318). I would prefer to keep it that way for now. Who knows if that will matter in the future when there are even less of these cars around.
Just the regular bolt ons with a cam upgrade will help. Changing the cam will help a decent amount even with stock heads, maybe something like the comp 268 extreme energy cam. I have the lunati 220/226 dur. @.050. 475/490 lift 112 lsa....i chose this because i have stock bottom end so low comp. This cam closes the intake valve early so it helps compression. I went with 273 adjustable rockers but as long as base circle is the same then your stock pushrods should be ok as long as you dont mill the heads or change head gasket thickness
I got a 74 charger se 318,904,81/4
I'm either going with the Summit 6900 cam or the Comp XE 256.
The Summit cam is a modern split pattern cam but is just big enough to fit under the stock valve spring specs. It's also a big enough difference to be quite noticeable at .444 EX lift vs the stock .399.
It's also $80.
I have a very similar setup to you but might be a few pounds lighter.
My 318 has 60K original miles and is super clean inside.
I have dual exhaust already with manifolds, and I have a performer intake to go on and a 600 AFB or 650 AVS plus a set of "302" heads waiting in the parts bin.
I'd like to at least keep up with the V6 mustangs.
...and be able to pass almost as many gas stations.
...there will now be debate about changing springs.
While that is going on, there will probably be no debate about getting new lifters to go with a new cam...and break-in.
As the great motor guru Steve Dulcich once told me about choosing a cam, he said. "Take the numbers from a Stock cam duration and add no more than 10% to that, and add no more than .050" of lift from stock, and you'll have a hot street car that can use the stock converter." I kept my parameters within that 10% on a 383 and I can say that I do have a hot car! Stick with this advice! Good Luck
I kept my block but changed everything above that with Edelbrock Parts. I also used the Edelbrock cam, as well. Mine is a 69 Sat Sport 318 4bbl with headers and dual exhaust. It has a new TCI 904 and a Sizzler Torque converter from TCI . The rear end is a 2.71. but will be upgraded to a 3.21 Sure Grip.
U got any time slips with the satellite mutt71? I got 74 charger, 318 lunati 220/226 dur. 475/490 lift 112 lsa, pro comp aluminum heads, edelbrock rpm intake, 600 vac carb. 904 3000 rpm stall manual valvebody, 8.25 with 2.71 open for now maybe 3.55 or 3.90 sure grip soon interested how your 318 move the satellite?
I hoped up my '78 - 318 like this;
600-AFB (I would do a AVS now)
Factory trap door air cleaner
Edelbrock LD4B intake (A Performer would be fine or even a factory 4bbl. for in the cheap)
Hooker headers, Jegs Dual exhaust
Crane cams, 218/226 @ .050 (?) 272/284-.454-.480-112
MSD ignition
Recurve distributor
Your 3.55's and assumed stock tire will be a nice upgrade and cruiser.
No time slips yet, as it is still in the body shop. Sorry.
I built a 318 for my Charger just a little bit ago (I actually did the first start up yesterday!) and I used a summit racing street/strip mild cam. For the springs I just used replacement 340 springs comp spring retainers. I RECOMMEND HEADERS TOO! and the eddy intake helps, too.
Specs on my motor..
bored .40 thousandths over to 3.95"
Stoke sroke
High volume oil pump
Double timing chain
Cam spec: Duration 272/272 and Lift .454/.454 Part number is SUM-1789
Valve Springs: 340 Stock replacements from rockauto
Stock heads
stock 8.6:1 Compression....
I will let you know how much power my combo has when I break it in...
I havent got mine out on road yet but the 318 will smoke the crap out of the 275/60/15 goodyear eagle st tire with the 2.71 gear set i want to go to 3.55 or 3.90 sooner or later
