Sixpactogo
I am starting to think my Charger has a Demon....................
I have a 6.1 Hemi in my 68 Charger with the factory computer and a Hotwire engine management system running the engine and 545RFE system. I have a GPS speedo that works intermittently. It seems to get a good signal as the GPS clock fires up and is accurate. I thought my antenna was weak so purchased another but my problem is elsewhere. I have taken my gauge cluster out of the car and hooked it up to a 12v portable battery in my daily driver and it tests out fine. I even put the antenna sensor under the seat and it monitored my speed without interruption. I put it back in my Charger and the speedo will only register the speed once in a while for like a block or so the drop to zero. I have tested my source to the speedo and it is 12.4V (battery voltage) without the engine running. 14.4 with engine running. (same as the rest of the system) My cluster is properly grounded. My plan now is to hook my 12V portable battery to the speedo and test it again thinking maybe the speedo doesn't like the 14.4 volts my system is sending to it. I did unhook the alternator but that didn't help so it must be getting some interference from from my system that it doesn't like.
Anyone experience this before or is my car possessed?
Here is a pic of the speedo. I have driven the car close to 100 miles and most of the 20 miles on the odometer are from my daily driver.
