SOLD Seat Belt Hardware
holanae
10:19 AM
Houston
I am looking for a set of seat belt bolts for my 68 charger.
Hello Ernie,
Here is what a 1968 Charger seat belt bolts that are required. Well at least that's what mine has.
10 total bolts are used if equipped with shoulder belts. Headliner (2), Drive-Shaft Hump (2), Rocker Panel (2) and rear floor board between rear foot-well & trunk pan (4).
C 10 bolts (2) used on retractors (rocker panel)
C-11 bolts (4) used on headliner (2) and 2 at the rear
C-12 bolts (4) drive-shaft hump (2) and 2 at the rear w/spacers.
Of all of these bolts I have the 4 C-11 bolts only at $3.00 each if you're interested.
Thanks, Bryan
Thank you for all the details. Let me see what everyone has, might be able to piece together a set. Your 4 plus the other six needed.
No problem. The spacers themselves are hard to come by, you might have to fab some of your own. I have the specs if you need them.
Thanks, Bryan
Spacer & specs?
There are these spacers that are used on 2 of the 4 back seat belt bolts. They're a sleeve type spacer or some call them a washer. What I meant by specs ifs that I could measure mine OEM spacers to give you an ideal of what it would take to make your own if you couldn't find any.
Thanks, Bryan
Here's a pic of one.
Can you get me the dimensions of the spacer. Also, where do they go on the rear. Behind the rear seat, or to the sides of the rear seat?
Thanks, Bryan
Washers/spacers
OD = 11/16"
ID - 1/2"
Thickness = 1/4"
These are used on the 2 rear seat belt bolts towards the center of the floor board. The ones that have 2 belt strap eyelets using the same bolt. The spacers go between the 2 eyelets.
I may just end up having a complete seat belt bolt set including washers as I just got a 68 B Body car to part out this Sunday(5-15-16). I have not checked the belt situation yet but I'm most certain that they are there.
I have a guy that might have a set for me. I will let you know. Thank you for the help thus far.
