WTB Mopar hoarders! Looking for hard to find parts!
69CudaFan
12:31 AM
Poway, CA
Mopar stashers, check the corners of your garages, storage units etc. seeking the following:
2949065 radiator 22inch core to an automatic
2785614 22 inch radiator shroud.
2892093 727 transmission. Built prior to 1 December 1968, blank vin pad
(Long shot on vin 9B236779) Julian date should be 2600-2675
First two might be a pipe dream on this forum, but you never know what folks have squirreled away. PM me with what you have!
Where do I find the ID #s
Might have better luck at Forabodiesonly. I need the radiator also. Seems people want $$$$ for a rebuildable core. Then another $500 to recore it, then another $120 for the shroud mounting brackets. Repop shrouds are available. Good luck.
I have my feelers out at Forabodiesonly as well. They fetch some serious coin.
I also would like a 2875758 distributor that is date coded from 32 8 to 42 8, best possible condition.
On the radiator, it is on the top tank. There is a date code on the mounting bracket as well.
The shroud is embossed with the P/N and Chrysler logo.
The transmission has it stamped on the rail along with the plant of manufacture and a Julian date on the side. The VIN pad is on the passenger side.
The distributor may be embossed or have a tag affixed to it.
Also looking for a 440 single point distributor
2875758 build date prior to 1 Dec 68 (i.e. "31 8")
Do you need..
Front turn signal lights
Both tail lighs
Complete dash plus loom
Both grill inverts for grill. R and l
All for the paltry price of 350.00
Pm mr
Similar threads
