Darthomas
Is this available anywhere?
Electrical tape is just awful for the job.
That must be the stuff, thanks.
The non adhesive harness tape is very stretchy so when you are wrapping the harness pull it tight along the way. Then lock in the ends with a couple of wraps of regular electrical tape. There are probably other ways to do it but this works well for me.If it's non-adhesive, how will it ever fuse together like the factory original tape?
The original had an adhesive, just a different type that sort of hardened, instead of turning gooey.
The plastic of the tape itself was thicker and stiffer than electrical tape; a different type of plastic.
Shrink tube maybe?
Your original harness tape is old and has hardenedIf it's non-adhesive, how will it ever fuse together like the factory original tape?
Likely, yes.Your original harness tape is old and has hardened
over time.
