have car will cruise
Hello. I'm new to this forum and to the B-Body world.
This my situation. I'm replacing leaky steel core plugs from the 440 block in my '68 Coronet. This has been a pain in the butt with the engine is still in the car. I'm using several different methods to remove them (4 out so far). Using a punch to "rotate" worked on 2 of them and self tapping screw and slide hammer on the other 1 & 1/2. While removing the 2nd plug (the one behind the starter) with the screw method , the plug buckled and the screw went into (through cylinder wall?) the block. I was using #8 Screws, so the hole hole is approx. .160". What are my are my options to fix this? Help please.
Thanks in advance ... Im a bonehead...
aboard!![IMG_1650[1].JPG IMG_1650[1].JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/275/275725-179b1b3ca8c68635f438288727f55ea3.jpg?hash=F5sbPKjGhj)
