Problems with Air Grabber on 70RR
Lucky Lar
2:55 PM
San Rafael
If I bypass everything and attach a vacuum line from the fitting on the intake manifold to the air grabber valve on the hood it opens right up
If I insert the vacuum canister between the vacuum fitting on the intake manifold & the air grabber valve on the hood (still bypassing everything, switch ect.) It won’t open all the way
Do the vacuum canisters go bad?
Can the vacuum canisters be fixed ?
Also can anybody explain how the vacuum canister actually works?
Thanks, all comments would be appreciated
The canister is bad probably where the bracket is welded to the can itself I've seen them crack from vibration there
I have seen 2 types of canisters one has ridges like the photo below
and the one i have is all smooth, do you know which one is correct?
