Whose front disc brakes are these?
Richard Cranium
7:40 AM
New Hampster
They are on the Charger I just bought.....
Rc, They do not look like Bendix 4 piston Brakes, which would be correct for a 68 car. I know, as I had the Bendix on my 68 RR. Perhaps they are the Kelsey Hayes variant.
SSBC brakes. The conversion kit that uses your original drum brake spindles.
^^^^^^^^^^^ Yep,SSBC Had that set up on a 65 Belvedere.
Manual. Did the rears too with SSBC.Stops very well
Witch Master Cylinder? 15/16?
I want to drive SSBc in the Front and Drums in the rear with Manual Master Cylinder
I believe so. It was 14 years ago......
Look on the dust cover^^^^ I used these on my 65 since went to wilwood.:steering:Them are furd calipers
I've never seen a brake line connect to hub side of a caliper before!!!
Pretty sure that line passes fluid from the inner pistons (inner half of the caliper) to the outer half. The fluid delivery from the framerail is delivered essentially the same as usual, to a separate input port to accept the brake hose.
I have an old Wilwood Grand National caliper designed to operate like this, but is missing the line. Note the connector at the left side of the caliper, and the recess made for the line:
Vintage 1970's-80s Wilwood Grand National 6-Piston Brake Caliper - Gold Anodized by cudak888, on Flickr
My Hurst Airheart has it too, but so happens that the only photo I have of it on hand at the moment is of the wrong side, though you can see the fitting to accept the brake hose in the center:
Hurst Airheart brake calipers by cudak888, on Flickr
-Kurt
Thanks C888,
Looking back we could never afford to mess with the high end brakes, lol! It was all oe stuff
I'll have to look at my 4 piston Wilwoods again, but I'm thinking the crossover is internal I don't remember seeing a jumper...
Thanks C888,
That Wilwood Grand National I posted is from the mid-'70s-early 1980s. Ancient history.
Your new 4-pistons are probably completely different in design.
-Kurt
