FOR SALE Milodon dual line external oil system - brand new
gkent
7:18 AM
Ontario, Canada
Feedback: 4 / 0 / 0
Everything is BRAND NEW. It’s been installed on the motor and manually primed ONLY – never run.
Here’s what you get:
Milodon oil pan p/n 31470 (see actual specs below)
Milodon swivel pickup p/n 21330
Milodon dual line adapter p/n 21350 (pump spacer)
-12 AN fittings and braided hose
BONUS:
• The internal corners in the 90* elbows have had the sharp machined edges taken off and blended. All inlets or outlets on the elbows have been radiused. All this is done to reduce cavitation and improve flow which results in less strain on the pump drive and cam gear as well as a (minimal) HP gain.
• The pickup has been installed PROPERLY and does not leak (the trick is pipe sealant on the fittings and O-rings inside the pan – no need for messy silicone)
Note: the assembled photo is for reference only. This sale is for the items listed ONLY. The sale does NOT include a pump, pump cover or the hard line.
Reason for selling: change of plans.
Pan as described by Milodon
383-440 & HEMI - 81/4" DEEP, REAR SUMP
Originally designed for Super Stock campaigners and today used on all Super Comp, Super Gas and bracket classes as well, this design moves the sump completely to the rear where it should have been in the first place, and where the oil wants to go! Fits '65 and later chassis for all wedge and Hemi engines. Pan and Milodon oiling system will allow the 8500 RPM plus range. Uses a tie rod tube through which the drag link is inserted after engine installation. Minor drag link modification may be necessary due to frame, steering and engine mount misplacement or movement from stock.
Pan Capacity is 9 Quarts Plus Filter -
8 1/4" Sump Depth
There is over $800. Worth of stuff here and its All BRAND NEW.
Asking $600.00 plus the ride.
Might consider selling some pieces separately.
more photos available
No pump spacer.
NEW PRICE ... $550. FIRM
includes pan, pickup, fittings and lines
BONUS:
8 1/4" Sump Depth
View attachment 358192 View attachment 358193 View attachment 358194
Hello,
Do you still have the pump, adapter and cover for sale?
Sorry, that stuff is gone. Only stuff left is what's listed ... pan, pickup, fittings and lines.
Ok thanks for the quick reply. Was it all Milodon parts? I couldn't tell from the pictures who made them. A make or part number for the cover would help me tremendously.
Thanks again
