B51 fender tag code disk brake or not
Joske2
6:29 PM
Belgium
Hi guy's,
I have a 70 road runner with the B51 fender tag code.
i do not have the broadcast sheet from the car.
The car has power brakes, but it has drums on all 4 corners.
when i searched the internet, there is apparently a lot of confusion with this code,
if the car should have disk brakes or not.
Mine has 10 inch drums in the front and 11 inch drums in the back, which i think
is not correct.
it looks like it has the right booster for disk brakes , but i am not sure.
any help appreciated.
B51 69-71 Power Brakes
which is drums all the way around
disc brakes would be b41 or b42
B51 only tells you the car had power brakes. It doesn't tell you if the car had disc or drum brakes.
this is what i tought also, B41 should be on the broadcast sheet wich i don't have.
Drum brake car , should it not be 11inch on all 4 corners?
I found this online...... unfortunately, I don't have my fender tag info with me for my original power front disc '70 Roadrunner. I will see if I can remember to take a picture of my fender tag tonight. This list shows B51 as "power assit disc brks"
http://www.mopar1.us/build.html#brakes
Brakes Trim Transmisson Axles Engines
code Description code Description Code Description
B02 9x2.5" frt drums 72 C34 front seat shield D36 HD 727-a torflt 69-71
B05 10x2.5" frt drums 72 C52 Bench seats D36 727-b torqueflite 72 up
B06 Skid Contrl ABS C55 Bucket seats D41 HD clutch
B11 HD drum br E bdy C56 Dual recl buckets D49 spec order trans 69 71
B11 std duty frt dic brk C56 bucket seats 1972 up D51 2.76:1 Axle ratio 69 71
B12 HD frt disc brks C57 60/40 seats w recl. D51 2.71:1 " " 72 up
B13 taxi fr disc C58 50/50 bench seat D52 2.94:1 69-74
B22 9x2" rear drm brks 72 C61 reclining pass seat b/s D52 2.93:1 75 up
B25 10x2.5" rear drum brks C62 LH 6-way Man.Adj bucket D53 3.23:1 69-74
B26 11x2.5" rear brks taxi C65 Air foam bench seat cush D53 3.21:1 75 up
B28 11x2.5" rear drum brks C68 Carpeted fr floor mat D55 2.45:1
B31 11" HD man drum brks C69 Carpeted rear fl mat D56 3.45:1 dana 60 69-71
B41 Frt disc brks some yrs power C71 Air foam seat fr&rear D56 3.55:1 69-74
B42 Frt HD disc br some power C73 foldown Rear seat back D57 3.91:1
B43 Manual brakes C74 Shelf panel Folding D58 4.10:1 dana 60 69-71
B51 power assit disc brks C81 HD fr seat sprg D68 standard axle
C02 S/W cargo carpet C83 HD rear seat sprng D69 special order rear axle
C07 litter con. C92 Accessory flr mats D72 3.23:1 6cly
C12 shoulder belts C93 Carpeting D81 7.25" Axle
C13 frt shoulder belts C96 Spare tire cover D82 8.25" or 8.36" axle
C14 rear shoulder belts C97 trunk dressup pkg D84 9.75" dana 60 axle
C15 Deluxe seat belt D11 3-spd man tran 69-71 D85 9.25" axle
C15 spec.sound insul. pkg 70s80 D12 3-spd man tran D91 Sure grip diff
C16 console w buckets D13 3-spd man tran floor D99 special order trans
C20 delete console D14 3-spd man col shift E06 special order 6cyl
C21 center seat foldown Armrest D15 HD 4-speed M/T E08 spec.order 8cyl
C22 rear armrest w/o ashtray D21 HD 4spd man E11 170 1bb 6cyl
C23 rear arm rest w ash D24 4 spd man w/o-drv E20 225 6cyl export
C25 floor therm insul D30 TorqueFlite auto 82 & up E22 198 1bb 6cy
C25 left head restraint 69 D31 Ligt duty 904-A T-Flt E24 225 1bb 6 cyl
C26 Over head rf consolette D32 HD A-727 TorqueFlite E25 225 1bb 6cyl HD
C28 right head restraint 69 D32 some years A-998 E26 225 2bb 6cyl
C31 head restraint pkg 69 D33 A 999 Tor-Flite E31 273 2bb 8cyl 69
C32 head restraint delete D34 TorqueFlite Trans E43 318 2bb 5.2litre eec 8cyl
From Chrysler........
B51 = Power Brakes (Optional, w/Drums Standard)
B41 = Front Disc Brakes (Optional)
B51 & B41 = Power Brakes with Front Discs
