WTB need 67 GTX rocker panel trim clips
440Plymouth
11:40 PM
Ashburnham, MA
I have a 67 GTX that had a recent paint job. I ordered the rocker panel trim clips from Classic Industries. They informed me the parts are on Intergalactic backorder. I have checked with several sights with no luck. I even contacted a parts manger in VT, who I was told, had the means to locate Mopar parts. No luck. The Classic Industries Item# is MN1437. The Chrysler part # is 6001750. I have two clips and need 16 more. Please PM me if you can help. Thanks for your time,
Greg
I have always dealt with Tom over the years. If he didn't have something, it either didn't exist or wasn't available. GL.
I have about 10 different kinds of used Mopar rocker molding clips, message me with a pic and measurement of what you need and i will gladly check to see if i have any for you
I do not know how to down load pictures but the measurements are: 1 1/2 x 1 3/4 inches. There is a hole in the center with a prong that goes into the car body and then a plug is tapped in to secure it. They are made of off white plastic. I will try to figure out how to send you a picture. Thank you for your reply.
Does anybody have their own trick to remove these rocker molding clips? I have used a tiny drill bit to drill tiny hole in the center plug then screwed in a small screw and gave that screw a pull with a vice grip. Is there a correct way to remove these clips?
