Reproduction build sheet
VEGETA97
7:40 AM
Dodge, nebraska
Anyone know where I can get a reproduction build sheet for a 1970 dodge charger? Any help would be appreciated. Thanks in advance.
This a very touchy subject for many. I personally don't mind someone wanting a show display piece as long as its not ever represented as an original or anything of the sort. I don't know of any service that makes anything close to a spot on original (thank God). With that being said, if you want to make one for your vehicle (just for fun), here you go:
http://www.moparts.org/Tech/tech/logos/build-sheet69.pdf
In your browser, change the 69 to 70.
Kind of what I'm looking for, but more along the lines of what specifically per my vehicle. Trying to verify if it is a standard r/t or a r/t-se. from the info I've gotten from others (ie: body trim molding on rockers, factory ac, auto on column and buddy seat option) they say they lean to 99% r/t-se. unfortunately the original broadcast sheet is mia from the glove box and or rear seat. I'm going to check behind the plastic of the seats tomorrow. if not I'm not sure where or how to find out for sure that information specifically
You may also want to look under the front seat(s), the carpet and in the sail panel area. GL.
Do you have the fender tag for your 70 Charger?
Only place I can look is the front seats. no carpet, glove box insert and nothingness the sail panels (I pulled those yesterday). I'm hoping, otherwise I may try to contact dodge directly and see if they have a way or something. if anyone else has an idea or suggestion, I'm open to them. thanks
Yes I have the fender tag, but I didn't find a way to decode if it was an r/t-se or just an r/t. I can post a pic of the fender tag tomorrow if you guys think that may help.
post up someone will give you the info your looking for
Here's the tag. maybe you guys can be able to tell me if it's an r/t-se or not
Well you should have found something out by now from the above reply #9.
'XS29' the 'S' makes it look like an R/T.
No 'A47' Special Edition Package which would give you Leather front seats (your tag shows vinyl seats C6XA), chrome trim around the go, stop and stay stopped peddles.
Your tag has some funny stamping on it.
One being the build date of what looks like 'A56', A = Oct. but Oct. does not have 56 days in it, it has to be a 0 or 1 or 2.
One being the 'UCG' the 'C' should be a '0'.
If it's an s/e shouldn't it have the emblem on the upper quarter panel behind rear window,the holes should be there where it was affixed
The shadows play tricks but SPD is Definitely A06 (October 6) and engine-year-plant is U0G
You are correct on the build date code and plant. The reason people have said it may be an R/t SE is the fact of rocker molding, factory a/c and pretty sure it has a slight green tint to glass from what I've gathered. Either way it is a good find.
I would like to see a larger clearer picture of the fended tag please.
Yes, a very good find, there still out there.
Here's the best ATM. I'm gonna try to make an impression in clay later to see if it will pull it in clearer
Put your info into a site I was given yesterday
XS29:
Dodge Charger
Unknown
2 Door Sports Hardtop
UOG: Unknown
Unknown
St. Louis, MO, USA
138237: Sequence number
E86: 440 cid 4 barrel V8 (High Performance) 375hp
D32: Heavy Duty Automatic Transmission
E87: Exterior Color
C6X: Trim - Charger, Vinyl Bucket Seats, Black
TX9: Int. Door Frames
A06: Build Date: October 06
023072: Order number
V1W: Full Vinyl Top, White
A01: Light Package
B51: Power Brakes
C21: Center Front Seat Cushion
C55: Bucket Seats
G36: OS Dual Racing Mirrors
G33: LH Remote Racing Mirror
H51: Air Conditioning with Heater
J25: 3 Speed Wipers
J45: Hood Tie Down Pins
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M25: Wide sill moldings
M31: Belt Moldings
N85: Tachometer
R22: AM Radio with 8 Track (10 Watts)
V6W: Longitudinal Stripes, White
26: 26in Radiator
END: End of Sales Codes
